CReinhard
Dec 11, 2018Aspirant
RBR50 Keeps Droping
I have the Century Link C3000Z @x DSL Modem . Its set to give out DHCP Addressing - I origionly thought it was the problem and now that they have replaced it twice all point to the Orbi system The RB...
Dec 11, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
CReinhard wrote:
@I have the Century Link C3000Z @x DSL Modem . Its set to give out DHCP Addressing - I origionly thought it was the problem and now that they have replaced it twice all point to the Orbi system The RBR50 , RBS50 and RBS40 all on Firmware version 2.2.1.210 the Orbi systems seems to haphaserdly lock up and loses its conection to the internet .. its very anoying , Any ideas as to why this seems to be progresivly getting worce ..
