CReinhard
Dec 11, 2018Aspirant
RBR50 Keeps Droping
I have the Century Link C3000Z @x DSL Modem . Its set to give out DHCP Addressing - I origionly thought it was the problem and now that they have replaced it twice all point to the Orbi system The RB...
CReinhard
Yes the orbi is and always has been in AP mode
Dec 11, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using? Set WPA2 and AES only instead of AUTO.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
I would also try the orbi in router mode and use the modems DMZ to see if the router still looses internet from the modem. Option #2...
