arthurpolo's avatar
Aug 09, 2022
RBR50 Keeps dropping Internet
I have the same issue. I down graded my firmware and it was stable for a while until the orbi automatically upgraded itself and then started dropping it again.
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • arthurpolo's avatar
      arthurpolo
      Tutor
      Hi, let me try and answer your questions:
      The Orbi RBR50 is set up as an AP.  I have two different AP solutions in my house, the Orbi rbr50 and TP-Link Omada's 245's (also acting as AP's) with an ubiquiti edgerouter X handling DNS and other things.
      1. The Omada's are not losing connection to the Edgerouter (ever)
      2. The Orbi does, after a firmware update, lose connection to the Edgerouter daily
      3. The edge router is not losing internet
      Orbi has firmware V2.7.4.24. I have powered off an cycled the Orbi and Edgerouter. The only fix I have found is to reboot the Orbi. When I downgraded the firmware to 2.7.3.22 the problem went away but the router keeps automatically upgrading itself to the latest firmware re-introducing the problem.
      A factory reset has not been performed, I hesitated to do that since the firmware downgrade worked, and frankly it is a pain.
      • FURRYe38's avatar
        Does the Orbi continue to drop internet with the other AP system turned OFF?
        What channels are being used on the RBR and this other AP system?
        What is the distance between the RBR and this other system? Feet?
        Too Much Wifi: https://youtu.be/UR0viMLISz4
