MFrerich
Sep 24, 2020Aspirant
RBR50 keeps hanging
OK...Been having a problem for the last few months and it is getting worse. I need some help before I decided to replace the Orbi completely. I have an RBR50 with 2 RBS50 and they are on the la...
Sep 24, 2020Guru - Experienced User
What mode is the ISP modem in? If router, the Wifi radios on this modem should be fully turned OFF. Full bridge mode is recommended on the modem however.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option#1 first if possible. Then try #2...
If you turn OFF the RBS and leave just the RBR online. Does the RBR hang or experience this issue.
Do both wireless and wired devices stop betting internet services when this happens?
Does the RBR show any top ring light when then happens?
MFrerich
Sep 25, 2020Aspirant
Well Powering off the RBS50s did not help, the RBR50 hung again this morning, the good news is it was able to recover on its own.
Also today there is not as many devices connected, I was actually away from the house when the issue happened, so no Smart Phone connected, no Laptop or computer and no SmartTVs on. This is why I don't think the system is over loaded becasue there are days when I have way more devices pulling data and the system does not have an issue.
Any other thoughts out there?
