ChuckTbaum
Mar 23, 2021Tutor
RBR50 keeps losing internet since firmware 2.7.2.104 update
Ever since I updated the Firmware to 2.7.2.104 I have intenret issues. When I bypass the router and connect direct to the modem its fne but The Orbi has no internet. I can login and see the Orbi and ...
Mar 23, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
v104 works for me.
ChuckTbaum wrote:Ever since I updated the Firmware to 2.7.2.104 I have intenret issues. When I bypass the router and connect direct to the modem its fne but The Orbi has no internet. I can login and see the Orbi and the 2 satelites but no internet. If I power cycle them then they will work again for a while but soon stops again.
Anyone else having these issues? Can I go back to previous stable Firmware?
vajim
Mar 23, 2021Master
FURRYe38 wrote:Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
none of the above will recitfy 2.7.2.104
- ChuckTbaumMar 23, 2021Tutor
Yes, once I starting having problems I shut ISP modem and Orbi router and both satellites down for 5 minutes then brought up modem and connected direct to modem with normal internet. I then brought Orbi router back up untl it was full online then each satellite seperately. Interent will then work for a while then eventually will stop again, When it does, I disconnect the Orbi and connect direct to modem without restartng the modem and I have internet.
I have had this Orbi for 2 years with no change in configuration. the only change is firmware. Maybe a factory reset is the next step?
- vajimMar 23, 2021Master
ChuckTbaum wrote:Yes, once I starting having problems I shut ISP modem and Orbi router and both satellites down for 5 minutes then brought up modem and connected direct to modem with normal internet. I then brought Orbi router back up untl it was full online then each satellite seperately. Interent will then work for a while then eventually will stop again, When it does, I disconnect the Orbi and connect direct to modem without restartng the modem and I have internet.
as long as you don't end up with 2.7.2.104 again
It sounds like the best solution is to use an older router until NG releases a new stable firmware unless I can install an older stable firmware.
- FURRYe38Mar 23, 2021Guru - Experienced User
Yes, give the factory reset a a try. If it fails, then revert back to last working FW version.
FURRYe38 wrote:Yes, give the factory reset a a try. If it fails, then revert back to last working FW version.
as stated by the moderator, NG is working on a fix. factory reset will not fix this.
