ChuckTbaum
Mar 23, 2021Tutor
RBR50 keeps losing internet since firmware 2.7.2.104 update
Ever since I updated the Firmware to 2.7.2.104 I have intenret issues. When I bypass the router and connect direct to the modem its fne but The Orbi has no internet. I can login and see the Orbi and ...
vajim
Mar 23, 2021Master
FURRYe38 wrote:Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
none of the above will recitfy 2.7.2.104
ChuckTbaum
Mar 23, 2021Tutor
Yes, once I starting having problems I shut ISP modem and Orbi router and both satellites down for 5 minutes then brought up modem and connected direct to modem with normal internet. I then brought Orbi router back up untl it was full online then each satellite seperately. Interent will then work for a while then eventually will stop again, When it does, I disconnect the Orbi and connect direct to modem without restartng the modem and I have internet.
I have had this Orbi for 2 years with no change in configuration. the only change is firmware. Maybe a factory reset is the next step?
