ChuckTbaum
Mar 23, 2021Tutor
RBR50 keeps losing internet since firmware 2.7.2.104 update
Ever since I updated the Firmware to 2.7.2.104 I have intenret issues. When I bypass the router and connect direct to the modem its fne but The Orbi has no internet. I can login and see the Orbi and ...
striker69
Mar 23, 2021Star
I Had The Same Problem With RBK13, At First I Had To Reboot Every Day, Then A Few Times A Day. I Went Back To Previous Version Of Firmware. So Far So Good, It's Only Been One Day.
- vajimMar 23, 2021Master
striker69 wrote:I Had The Same Problem With RBK13, At First I Had To Reboot Every Day, Then A Few Times A Day. I Went Back To Previous Version Of Firmware. So Far So Good, It's Only Been One Day.
One day with a previous version is better than a life time with one that disconnects several times a day
- Ha_Ku_NaMar 23, 2021Luminary
Keep in mind. DCHP lease is usually set to 24h. Therefore you have to monitor this at least for more than 24h. If the porblem reoccurs try disabling traffic-meter. good luck
go back under your rock....this person is going back to a previous version.,,,,,you are pointless and rude
