ChuckTbaum
Mar 23, 2021Tutor
RBR50 keeps losing internet since firmware 2.7.2.104 update
Ever since I updated the Firmware to 2.7.2.104 I have intenret issues. When I bypass the router and connect direct to the modem its fne but The Orbi has no internet. I can login and see the Orbi and ...
Ha_Ku_Na
Mar 23, 2021Luminary
striker69 wrote:I Had The Same Problem With RBK13, At First I Had To Reboot Every Day, Then A Few Times A Day. I Went Back To Previous Version Of Firmware. So Far So Good, It's Only Been One Day.
Keep in mind. DCHP lease is usually set to 24h. Therefore you have to monitor this at least for more than 24h. If the porblem reoccurs try disabling traffic-meter. good luck
vajim
Mar 23, 2021Master
go back under your rock....this person is going back to a previous version.,,,,,you are pointless and rude
- Ha_Ku_NaMar 23, 2021Luminary
vajim Reflect your activity in this thread. -> no useful information from my point of view.
And please also read the community rules.
I attached them here.
- jkbreuerMar 23, 2021Aspirant
Can we mark reopen this thread as not being solved? The current message marked as the solution does not have a remedy for the problem.
vajim if you know of the exact solution, or can link to the forum with the precise solution it would be helpful.
- vajimMar 23, 2021Master
jkbreuer wrote:Can we mark reopen this thread as not being solved? The current message marked as the solution does not have a remedy for the problem.
The moderators and netgear firmware team are working a permanent fix
until then you can try various options from inside this thread and others
I tried to post a possible solution here:
