firefight16
Apr 30, 2023Aspirant
rbr50 keeps losing wifi or is very slow, just started this
Okay I bought a new RBR50 and sat. Nothing but troubles had to pay for help after a power failure and sats would not come online. Now seems to be losing wifi connection all the time and when I do hav...
CrimpOn
Apr 30, 2023Guru - Experienced User
firefight16 wrote:
App says connected 2.4 but login from browser says connected 5ghz?
This may be a case where our expectations about how computers ought to perform* does not match how they actually perform. When the Orbi web interface or the Orbi 'app' display information about Connected Devices, they pull information from some internal tables. Those tables do not update instantly when "something changes". Rather, there is some routine buried in the firmware that periodically goes through the device list and records status information.
Often when I arrive home, my phone connects to a satellite in the garage as soon as it detects an SSID that it recognizes. This connection is usually at 2.4G. I walk into the house, climb the stairs and my phone reconnects at 5G to the router I am sitting four feet from. But... the Orbi reports I am connected to the garage satellite at 2.4G. Open the phone Wireless Settings and it clearly shows connected at 5G.
After the swearing stops, I often pull up the Attached Devices screen again and find (shazam!) that the Orbi thinks I am attached directly to the router at 5G!
There is no documentation (that I have ever found) about how the internals of the router function, such as how often the router updates internal tables.
* Another example might be: why does it take almost three minutes for the bloody thing to turn on??? C'mon. It's a computer for God's sake. Well, it's doing something all that time and we users have no idea what.
firefight16
It worked fine for weeks, now instead of getting a solid connection and 300 plus speed I get kicked out and speeds of 50.
- CrimpOnApr 30, 2023Guru - Experienced User
firefight16 wrote:
It worked fine for weeks, now instead of getting a solid connection and 300 plus speed I get kicked out and speeds of 50.If this is a new purchase, Netgear provides 90 days of support. (Most of us wish we had found a reason to call within the first 90 days... before the time ran out!)
"kicked out" means that a device is connected to the Orbi WiFi and then..... (what?)
- firefight16Apr 30, 2023AspirantNo, since November in fact I had an issue after sorry had to pay, after power went out I could not get sat online, took them hours to get it running. Then it started to do this, in ready to return it
- FURRYe38May 01, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-SystemOne User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
