JohnPhotography
Jul 26, 2018Aspirant
RBR50 LAN Port Issues
I have an iMac running on High Sierra 10.13.6 that was working fine on my previous set up.
Today, I had Spectrum upgrade my cable modem to a GIG modem.
Wireless works flawlessly. Flies! ...
JohnPhotography
Aug 02, 2018Aspirant
The ethernet is connected as before and iMac still does not recognize it. I've pulled it out and made sure it was fully inserted into the port.
Yes, I'm currently using the iMac wirelessly connected to the Orbi.
Aug 02, 2018Guru - Experienced User
Is it getting an IP address when the LAN cable is connected? Turn OFF the wireless radio on the mac.
Look at the connected clients list on the router, is the mac listed at all here?
Try different ports on the router same thing?
- JohnPhotographyAug 02, 2018Aspirant
No, not getting a IP address. iMac is not recognizing the ethernet cable whatsoever. Yes, I've done the trouble shooting withi wifi turned off.
On the Orbi, i see the iMac connected via wirelessly. Doesn't even show the iMac being hardwired at all. Weird.
