Guapo_Apo
Mar 02, 2018Aspirant
RBR50 Lan Ports Not Working
Out of nowhere LAN ports on RBR50 have stopped working. WAN works great. Found this out as Smartthings hub went offline and Amazon video stopped playing. Will intermittently come back on of I reboot t...
Mar 02, 2018Guru - Experienced User
Would need more info your experiences.
What is the Mfr and model of the ISP modem? built in router by chance?
Is the ethernet cabling between modem and router and devices of good quality? Cat6 recommended. Don't mix Cat# cables.
What ethernet devices are you connecting to the router?
Try the suggestions I mentioned to see any changes in behavior with the router. Graduate adding devices.
Brain29wrote:I have the same issue every day I have to reset my router once because LAN goes down sometimes WAN goes out too but everytime it starts with LAN
V2.1.2.18
Is there a Fix
Would like a router to act like a router kind of pointless if it cant connect things
Brain29
Mar 02, 2018Apprentice
modem is a Motorola SURFboard SB6141 dirrect into the orbi
right now I have cat 6a but I have 5a and 8a on hand not sure why copper thickness or mix would make a router crash ???
satallite is connected wireless
- Brain29Mar 02, 2018Apprentice
everything connected to the router is the same that was connected to an old asus router that never dropped lan
- FURRYe38Mar 02, 2018Guru - Experienced User
What ethernet devices are connected to the back of the router? Mfr and model#?
Theres cat6 and CAT6a. Cat6A is in wall big cable for in wall and ceiling runs.
Cat 6 is standard patch cables used between home and office devices.
Cat 7 is targested for over 10Gb network services.
Cat 8 is designed only for data centers where distances between switches and servers is short. It is not intended for general office cabling.
Brain29wrote:modem is a Motorola SURFboard SB6141 dirrect into the orbi
right now I have cat 6a but I have 5a and 8a on hand not sure why copper thickness or mix would make a router crash ???satallite is connected wireless
"not sure why copper thickness or mix would make a router crash"
RBK50-100NAS
RBS50
samsung smarttv
harmoney hub
vontage phone servcie
3 workstations
2 raid servers (typically in idle)
wireless probally 8 phone and tablets (maybe 2 in use at one time)
