Guapo_Apo
Mar 02, 2018Aspirant
RBR50 Lan Ports Not Working
Out of nowhere LAN ports on RBR50 have stopped working. WAN works great. Found this out as Smartthings hub went offline and Amazon video stopped playing. Will intermittently come back on of I reboot t...
Mar 02, 2018Guru - Experienced User
Cables could be bad or not of good quality.
Which devices do you have connected via ethernet cable with the router?
Guapo_Apowrote:
Out of nowhere LAN ports on RBR50 have stopped working. WAN works great. Found this out as Smartthings hub went offline and Amazon video stopped playing. Will intermittently come back on of I reboot the router. Any ideas or is this hardware related?
Guapo_Apo
Smartthings hub, Playstation 4 and Sony TV. Disconnecting and reconnecting seems to have fixed the problem...
- FURRYe38Mar 02, 2018Guru - Experienced User
Wonder if there was some conflic or hang up with between these devices and the router.
Glad you got it working. Let us know if it happens again.
Guapo_Apowrote:Smartthings hub, Playstation 4 and Sony TV. Disconnecting and reconnecting seems to have fixed the problem...
