TommyH5
Jun 21, 2020Tutor
RBR50 Looses Internet 5-7 Times PerDay
Hello, My Orbi was great for six months but has been loosing the Internet 5-7 times per days for the last several months. A reboot restores the connection until the next time it drops. Xfinity ...
- Jun 29, 2020Xfinity finally came out and everything was fine on their end but he did show me that in the attic I’ve got RG59 running to the modem. Not good but I’m sure that I finally found the problem. House is 31 years old so I’m not surprised. Going to run some RG6 in through a window and directly to the modem this afternoon. If all goes well I’ll do the attic run this weekend.
Jun 21, 2020Guru - Experienced User
Is Armor or Circle enabled?
Did you power OFF the ISP modem for 30 seconds then back on when you did a factory reset?
- TommyH5Jun 21, 2020Tutor
Yes, one Wi-Fi neighbor. Armour and Circle are both disabled. Modem was powered down at least two minutes while doing the factory reset.
Thanks for responding.
- FURRYe38Jun 21, 2020Guru - Experienced User
So both wireless and wired connections stop working when this happens?
Try turning OFF the RBS. Does the RBR still experience problems?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
I don't have any wired connections only wireless. The RBS is 35 feet away also tried other locations even farther away. Already tried turning off the RBS but the RBR still looses internet. Already tried 1, 6, and 11 on 2.4 GHz. and 44, 48 on 5 GHz. Will try turning power down to 50%.
Also checked out the modem log. Many, many "No ranging response received -T3 timeouts".
Called Xfinity to ask for a service tech but because of the pandemic they may not be able to send one out since the problem is intermittent. Waiting to hear back. Want them to replace the entire cable run from the connection box outside the house up to the modem. No splitters and the existing run is over ten years old back when Xfinity was called Comcast. I'm even willing to pay for it.
Thanks again.
