harsh11's avatar
harsh11
Tutor
Jan 12, 2020
RBR50 LOOSES INTERNET CONNECTION EVERY FEW MINUTES AFTER CHANGING SERVICE PROVIDER FROM FRONTIER TO
RBR50 LOOSES INTERNET CONNECTION EVERY FEW MINUTES AFTER CHANGING SERVICE PROVIDER FROM FRONTIER TO SPECTRUM   EVERY FEW MIN LOOSES INTERNET CALLED SPECTRUM AND THEY SAY MODEM IS WORKING FINE CHECK...
  • plemans's avatar
    Jan 12, 2020
    1. to the left of the "A" key is a caps lock button. Please use it.
    2. What firmware is on your router?
    3. What modem did spectrum install?
    4. did you factory reset your orbi and reinstall it when you switched ISP's? Never a bad ideal when changing isp's.
    5. spectrum is great at blaming 3rd party equipment because it forces people to use their or pay for a service call. they also make it hard to check a modems connections as they block the access for a lot of their modems. Did they do this with yours?
    6. Is it wireless/wired thats dropping? both. A bit more details help. We're here to help you but we can't help you without details because we're not there.
