sweerik
Sep 23, 2022Aspirant
RBR50 looses internet connection
RBR50 with firmware 2.7.4.24 and 3 RBS50 and 1 RBW30 satellites looses internet connection intermittently. Local wifi and satellites works fine but the router just stops to be connected to Intern...
ekhalil
Sep 23, 2022Master
Is Orbi in Router or AP Mode? What is the make and model of the ISP router to which Orbi router (RBR50) is connected?
sweerik
Routermode.
Fiber box Icotera Model: i6405-50
- ekhalilSep 23, 2022MasterPlease use the web GUI (orbilogin.com) and tell us what settings you have under >> ADVANCED >> Setup >> Internet Setup
- sweerikSep 23, 2022Aspirant
Login: NO
Dynamic IP from ISP
DNS automatic from ISP
Standard Mac-address
DHCP option NIL
- KevinLiTSep 23, 2022NETGEAR Moderator
Hello sweerik,
Welcome to the NETGEAR Community!
Please use 8.8.8.8 and 8.8.4.4 for your DNS configuration settings.
Let me know if this solution was able to resolve your network stability issue!
Best,
Kevin
Community Team
- ekhalilSep 23, 2022MasterThanks,
Under dynamic IP from ISP, do you see a public or private IP address?
