RHRathje
Jun 30, 2019Aspirant
RBR50 loosing WIFI - Wired seems to work
I have an RBR50, and it suddently drops WIFI every 5-7-10 minuts. When it drops wifi, I still have wired connection to the internet trough my RBR50, but all units connected via WIFI looses connection...
- Jun 30, 2019
Update the system again and after the FW is updated, do a factory reset and this time, don't enable Armor at all. Leave it off. Setup the RBR as suggested.
RHRathje
Thank you for your reply.
Idon't know about the modem.
There are approx 30ft between my router and sat. and our flat is 140 square meters (approx 1500 square feet). We don't have many neighbours with WiFi.
I have tried everything you recommend, but It doesnt change anything. I have tried to enable Armor, and for some reason it seems to help. It doesnt eliminate the issue, but I don't loose WiFi just as often after.
