smcgivern
Jun 22, 2022Aspirant
RBR50 'losing' PPP device
I've had my RBR50 for about a year and it's been working great. Yesterday, I started losing my internet connection (I am not sure why but this is not my top priority right now), and was unable to rec...
Jun 22, 2022Guru - Experienced User
Check the ISP services to make sure nothing is wrong there.
Be sure your using good quality LAN cable between the ISP modem and RBR. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
smcgivern
Thanks for the response. To clarify, this seems to be working with the Archer C7 as the router and the Orbi in AP mode. While I cannot reproduce consistently, I think this should rule out network cable and client device issues.
I will see if I can find the ONT's make and model and try power cycling that in the order you suggested with the router.
- FURRYe38Jun 22, 2022Guru - Experienced User
Well if the Orbi in the AP mode then there shouldn't be any issues no the RBR as any PPP would be handled by the upstream router or ONT. Any internet traffic in AP mode on the RBR is just passing thru on the RBR in AP mode.
Be sure the RBR is connected on its WAN port to the host router on it's LAN port there.
I would set a static IP address for AP mode ON the RBR that's outside of the host routers default IP address pool.
- smcgivernJun 22, 2022Aspirant
FURRYe38 wrote:Well if the Orbi in the AP mode then there shouldn't be any issues no the RBR as any PPP would be handled by the upstream router or ONT. Any internet traffic in AP mode on the RBR is just passing thru on the RBR in AP mode.
Yes, this is what I am saying - the Orbi in router mode loses the connection and cannot reconnect without a reboot. An alternative router I have does not do this. I would like to just use the Orbi in router mode, though. I understand how to configure the Orbi in AP mode, that is not the question I am asking 🙂
Does the RBR show a top PINK LED when this happens if it's connected to the ONT in router mode?
If it does, would be contention on handshaking and maintaining connection between the ONT and the RBR. Possible lease time failure to reacquire the connection between the ONT and RBR if something is happening here. Would be something particular between the RBR nad your ONT. Haven't seen much if any other users posting with this behavior. CrimpOn runs a 50 series and would have said something about it. However I don't believe he uses ONT for ISP services.
Let us know the brand and model of this ONT...
