smcgivern
Jun 22, 2022Aspirant
RBR50 'losing' PPP device
I've had my RBR50 for about a year and it's been working great. Yesterday, I started losing my internet connection (I am not sure why but this is not my top priority right now), and was unable to rec...
smcgivern
Thanks for the response. To clarify, this seems to be working with the Archer C7 as the router and the Orbi in AP mode. While I cannot reproduce consistently, I think this should rule out network cable and client device issues.
I will see if I can find the ONT's make and model and try power cycling that in the order you suggested with the router.
Jun 22, 2022Guru - Experienced User
Well if the Orbi in the AP mode then there shouldn't be any issues no the RBR as any PPP would be handled by the upstream router or ONT. Any internet traffic in AP mode on the RBR is just passing thru on the RBR in AP mode.
Be sure the RBR is connected on its WAN port to the host router on it's LAN port there.
I would set a static IP address for AP mode ON the RBR that's outside of the host routers default IP address pool.
- smcgivernJun 22, 2022Aspirant
FURRYe38 wrote:Well if the Orbi in the AP mode then there shouldn't be any issues no the RBR as any PPP would be handled by the upstream router or ONT. Any internet traffic in AP mode on the RBR is just passing thru on the RBR in AP mode.
Yes, this is what I am saying - the Orbi in router mode loses the connection and cannot reconnect without a reboot. An alternative router I have does not do this. I would like to just use the Orbi in router mode, though. I understand how to configure the Orbi in AP mode, that is not the question I am asking 🙂
- FURRYe38Jun 22, 2022Guru - Experienced User
Does the RBR show a top PINK LED when this happens if it's connected to the ONT in router mode?
If it does, would be contention on handshaking and maintaining connection between the ONT and the RBR. Possible lease time failure to reacquire the connection between the ONT and RBR if something is happening here. Would be something particular between the RBR nad your ONT. Haven't seen much if any other users posting with this behavior. CrimpOn runs a 50 series and would have said something about it. However I don't believe he uses ONT for ISP services.
Let us know the brand and model of this ONT...- CrimpOnJun 22, 2022Guru - Experienced User
Alas, my RBR50 is connected to Spectrum Cable which is an Ethernet DHCP link.
brwan Link encap:Ethernet HWaddr A0:04:60:1C:xx:xx inet addr:172.249.112.xxx Bcast:255.255.255.255 Mask:255.255.240.0 inet6 addr: fe80::a204:xxxx:fe1c:23a/64 Scope:Link inet6 addr: 2605:e000:3fc0:3e:d2:xxxx:3c1a:e199/128 Scope:Global UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:126116452 errors:0 dropped:0 overruns:0 frame:0 TX packets:38601926 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:77188048459 (71.8 GiB) TX bytes:10573044234 (9.8 GiB)If the PPPoE connection has been working for a year and suddenly fails, my guess is that the ISP has changed something (perhaps not even realizing that they have). Firmware V2.7.4.24 has been working fine for me (since Netgear auto-updated it one night). I have not done a Factory Reset, but the router has rebooted a number of times due to Edison power outages.
I really doubt that Netgear would have made any change to the ISP connection with this firmware . My guess is that unless the ISP has a response, then sticking with the TP-Link router is the only practical solution.
