Sourmarie
Mar 18, 2025Aspirant
Rbr50 magenti light v.2.7.5.6
solid magenta. I've moved satellite to 3 feet away. I've changed wires from spectrum modem. I've confirmed i have internet by going straight from modem to pc. Help.
- Mar 18, 2025pc is on line. satellite is blue
Mar 18, 2025Guru - Experienced User
Was the RBS updated as well? Any and all RBS should be updated first before the RBR is.
Try to re-sync the RBS to the RBR?
Sourmarie
ok trying sync again. I have white light spinning on router, now stopped. internet still down
- SourmarieMar 18, 2025AspirantWhite lights on both router and satellite, I'm rebooting pc. Tried to open Gmail no go.
- FURRYe38Mar 18, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
