Stutters
Sep 30, 2023Aspirant
RBR50 mystery - PlayStation forcing star topology
Hi all. I have an RBR50 and 3 RBS50 satellites, all on the latest firmware (updated manually). My house is long and thin, with the RBR50 toward one side by necessity. I therefore have one satellite i...
Oct 03, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
- StuttersOct 04, 2023Aspirant
Thanks for getting back to me.
Answers below. Any idea why a PS5 may be causing the Daisy Chain to break down? I've run some further tests, and it's definitely this device that's the problem.
v2.7.5.4 on all devices, though the problem definitely occurred on the previous firmware as well.
I have my Orbi's set up in Bridge mode. I'm using a FRITZ!Box 7530 modem.
Check.
About 2,800
The first satellite is about 40ft. The second is a further 30ft. I've moved them around a little, but to no effect.
- KevinLiTOct 12, 2023NETGEAR Moderator
Hello Stutters ,
Welcome to the NETGEAR Community!
I understand that you are experiencing issues with your network topology settings. Please toggle the Daisy-Chain Topology off/on then restart your Orbi Mesh system (If it is on toggle it off then on again).
Please navigate to the following settings from your Orbi admin page:
ADVANCED
Advanced Setup
Wireless Settings
Backhaul Topology
Toggle Enable Daisy-Chain Topology
Then, Restart your Orbi Mesh SystemBest,
Kevin
Community Team- StuttersOct 13, 2023Aspirant
Thanks for this Kevin.
After having the PS5 disconnected from the network for a week, I reconnected it and it's behaving correctly. Before, the mesh would get confused within a couple of minutes, now it's been stable for a few days.
If it happens again, I'll try your solution and report back!
