Stutters
Sep 30, 2023Aspirant
RBR50 mystery - PlayStation forcing star topology
Hi all. I have an RBR50 and 3 RBS50 satellites, all on the latest firmware (updated manually). My house is long and thin, with the RBR50 toward one side by necessity. I therefore have one satellite i...
KevinLiT
Oct 12, 2023NETGEAR Moderator
Hello Stutters ,
Welcome to the NETGEAR Community!
I understand that you are experiencing issues with your network topology settings. Please toggle the Daisy-Chain Topology off/on then restart your Orbi Mesh system (If it is on toggle it off then on again).
Please navigate to the following settings from your Orbi admin page:
ADVANCED
Advanced Setup
Wireless Settings
Backhaul Topology
Toggle Enable Daisy-Chain Topology
Then, Restart your Orbi Mesh System
Best,
Kevin
Community Team
Stutters
Oct 13, 2023Aspirant
Thanks for this Kevin.
After having the PS5 disconnected from the network for a week, I reconnected it and it's behaving correctly. Before, the mesh would get confused within a couple of minutes, now it's been stable for a few days.
If it happens again, I'll try your solution and report back!
