MarkEF46's avatar
MarkEF46
RBR50 Need to extend coverage
I have and RBR50 with one RBS50 satellite, and the coverage in my basement is poor. I was thinking of getting a second satellite, but it looks like the RBS50 isn't being sold. Is there another satellite I can use or any other ways to make my coverage better? It's not that big a house.
  • I did a search and several places still have  RBS50 stock. Seems a bit expensive, but it may be worth it, if you want the same model satellite.
    • MarkEF46's avatar
      MarkEF46
      Thanks for the replies. I updated the firmware (thought I was up-to-date, but I wasn't) and I relocated my sattelite. Early indications are that these fixes may have solved the problem. I'll give it some time now and return to the board if I need more advice. Thank you!
      • FURRYe38's avatar
        Guru
        Let us know how it goes.
