DaleLyles
Jul 16, 2021Aspirant
RBR50: no firmware update from 2.7.2.104?
My wifi has been a bit flaky, and finally I checked the firmware on the devices. The RBR50 is running firmware version 2.7.2.104, as is one of the satellites (RBS60); the other satellite (RBS20) is r...
- Jul 17, 2021
Don't try to open the .img or .chk files. They are not usable my any OS. Just use a web browser and log into the RBS/RBRs web pages and use the FW update feature page to send the unpacked FW files to the RBS then RBR.
DaleLyles wrote:I downloaded that somewhere at the beginning of trying to figure this out, but my Macbook Pro does not recognize it as a file and won't open it.
Jul 16, 2021Guru - Experienced User
So manually install if you feel the need too:
NG may have not put the newer version up on there servers yet for auto updates. No idea if or when that will happen.
If you choose to, the update the RBS 50 first then RBR50 lastly.
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
If you don't then lets try to troubleshoot your system with what loaded on it already first as updating FW may not fix anything.
- DaleLylesJul 16, 2021Aspirant
- FURRYe38Jul 17, 2021Guru - Experienced User
- DaleLylesJul 18, 2021Aspirant
Finally. Thank you!
I would add that the path is https://http://192.168.1.1 > Administration > Firmware update > Manual update.
From there, update the satellites (which are listed) and then the router (which curiously is not listed/named).
