Littleden
Jun 05, 2020Aspirant
RBR50: no internet for new device that connects to Orbi (other devices work fine on the same network
Hi all, I have an Orbi RBR50 router, no satellite. The router works fine. However, whenever there is a new device connects the the network, all the existing devices work fine, but the new device show...
- Jun 05, 2020
Anyway, I follow the instruction as it said in this youtube clip (https://www.youtube.com/watch?v=JMOOayRplI4) and it works. I follow the solution #2. Thank you so much CrimpOn.
CrimpOn
Jun 05, 2020Guru - Experienced User
There is a setting on the Orbi web interface (http://orbilogin.net), on the Advanced Tab, Security, Access Control
There is an option to set "Access Control" to on or off, and when "on" there is a setting for
New devices ARE allowed or new devices are NOT allowed.
Can you please check this setting?
- LittledenJun 05, 2020Aspirant
Thank you for your reply. The setting is good, however, I was playin around with the setting of the internet on the PC. I changed the IP settings/assignment to Manual with IPv4 DNS to 8.8.8.8 and 8.8.4.4, which it worked. Then I checked the internet speed and it's slower than the other devices. I read on Google and someone recommedned 1.1.1.1, which I switched and it doesn't work :( I feel so bad about it. Now I change it back to 8.8.8.8 and 8.8.4.4 but it still doesn't work. Any recommendation on what to do next??? Again, thank you
- CrimpOnJun 05, 2020Guru - Experienced User
This is a strange situation. When a device asks for an IP address using DHCP, ordinarily the Orbi returns the IP address of the Orbi for the DNS server. That way, all devices connected to the Orbi query the Orbi for DNS, which the Orbi "caches". When a request comes in for an address not in the cache, the Orbi requests it and stores it in the cache. Since so many DNS ruquests are repetitive, this save a huge amount of internet traffic and is also much faster. (for example, "Where is facebook.com? Where is google.com? over and over again.)
The user has the option to do two things: (1) they can often set a specific device to use a different DNS server, such as Cloudflare (1.1.1.1) or Google (8.8.8.8). Here's a list of the "top five": https://www.techradar.com/news/best-dns-server This means the device totally bypasses Orbi's DNS system. (2) They can control which DNS server Orbi uses. When Orbi gets its public IP address from the ISP using DHCP, the ISP supplies the IP of DNS servers (which, of course, are part of the ISP network). The Orbi can be set to ignore that advice and use any other DNS server. Mine, for example, is set to use my own "Pi-hole" DNS which blocks advertising and tracking sites.
Both 1.1.1.1 and 8.8.8.8 are valid DNS servers.Millions of devices use them constantly.
Can you explain the meaning of "setting is good." Is Access Control "on" or "off"? Are new devices "allowed" or "blocked"?
Access control is ON and "Allow all new devices to connect". I have Windows 10 and I just "Network reset" as I was browsing online, hope I did not make it worse. Anyway, so now the PC connects to the network but "No Internet, secured" and later it shows "Connected, secured" but still no access to the internet. I really don't know where to go from here. Please advise.
