bsterling
Mar 08, 2021Tutor
RBR50 No internet from ethernet ports
This weekend I lost internet connection for everything connected via ethernet in my main unit. Wifi still works great. I do have a switch and it still shows connections, just no internet. I have t...
- Mar 08, 2021
Seems like a hardware failure at the RBR. :smileysad:
vajim
Mar 08, 2021Master
you may want to roll your firmware back.
lots of problems being reported with V2.7.2.104.
- bsterlingMar 08, 2021Tutor
Thanks guys- I will try a rollback first and then will do a factory reset. Very interestingly, the ethernet ports on the satellites work...
- FURRYe38Mar 08, 2021Guru - Experienced User
Try a factory reset first with v104 loaded. Should clear out anything. I would also power OFF the RBR for 30 seconds then back ON.
bsterling wrote:Thanks guys- I will try a rollback first and then will do a factory reset. Very interestingly, the ethernet ports on the satellites work...
- vajimMar 08, 2021Master
FURRYe38 wrote:Try a factory reset first with v104 loaded. Should clear out anything. I would also power OFF the RBR for 30 seconds then back ON.
already on the way to a roll back....sorry
