dettrie
Feb 27, 2020Guide
RBR50 no internet on WiFi for some Devices
We’ve been using an Orbi RBR50 router plus one satellite. We have multiple devices connected through wifi, including several WiFi lights, cell phones, tablets, etc. within the last month several devic...
Retired_Member
Feb 27, 2020
dettrie wrote:
I’ve checked the firmware of the router and the satellite, and both are up to date.
Confirming that the FW is update to date is not always a safe bet.
How long have you gad your Orbi and has it ever worked fine before this problem?
- dettrieFeb 27, 2020GuideWe’ve had the router for just over 2 years. It worked perfectly until about 3 weeks ago. Nothing has changed with the setup, outside of adding additional devices that connect to WiFi and then updating the firmware when it stopped working.
- Retired_MemberMar 01, 2020
dettrie wrote:
We’ve had the router for just over 2 years. It worked perfectly until about 3 weeks ago. Nothing has changed with the setup, outside of adding additional devices that connect to WiFi and then updating the firmware when it stopped working.any time 'YOU' update the FW your network may be suspect. If after trying all of the offered suggestions with no satisfaction, you may want to roll your FW back to where you believe it was the last time it worked. In the past if you did manual FW updates, you may wan to stop that practice.
- dettrieMar 01, 2020GuideIt wasn’t working before I updated the firmware either. When I first started having problems I read through the Orbi troubleshooting steps and updating the firmware was one of the suggestions. When I say I updated the firmware, all I did was press the check for updates button and it updated.
