wharfedalemfm
Apr 14, 2018Tutor
RBR50 no internet, WAN port keep "detecting"
I bought RBK50 new 2 weeks ago. My setup is this: Internet-Cable Modem (Arris SB6141, Spectrum) + RBR50 in router mode (firmware 2.1.3.4 plus one satelite, same firmware version). I've always had int...
- Apr 14, 2018
Exactly followed the instruction and did the reset for both router and satelite. But I did not disable the "port protection and DoS attack" as well as the uPnP. Fingers crossed..
wharfedalemfm
Apr 14, 2018Tutor
Brain29
Apr 14, 2018Apprentice
email or call support
I have the same issues and have been for the longest time been on a support email thread for a good month and they have no soultion other then RMA - they also say there is no documented issues like this and default to hardware issues
If you don't want to RMA then just return it and go with a diffrent company
netgear really botch this product with there crashing firmware
