wharfedalemfm
Apr 14, 2018Tutor
RBR50 no internet, WAN port keep "detecting"
I bought RBK50 new 2 weeks ago. My setup is this: Internet-Cable Modem (Arris SB6141, Spectrum) + RBR50 in router mode (firmware 2.1.3.4 plus one satelite, same firmware version). I've always had int...
- Apr 15, 2018
Exactly followed the instruction and did the reset for both router and satelite. But I did not disable the "port protection and DoS attack" as well as the uPnP. Fingers crossed..
Apr 15, 2018Guru - Experienced User
Ok, keep us posted. You can keep DDOS and port protection enabled for safety. You can try both ways and see as well.
My system is working just fine for me. And others.
wharfedalemfm wrote:Exactly followed the instruction and did the reset for both router and satelite. But I did not disable the "port protection and DoS attack" as well as the uPnP. Fingers crossed..
wharfedalemfm
Apr 25, 2018Tutor
So far so good. Thanks everyone.
- FURRYe38Apr 25, 2018Guru - Experienced User
Enjoy.
