Crasje
Aug 24, 2023Tutor
RBR50 no longer detects satelites
hi, i noticed on the app that the satelittes were no longer connected. So I brought them closer to the Router and pressed connect on all 3. They all started blinking white for short period, one o...
- Mar 21, 2025
conclusion was that the satellite is broken beyond fixing/rebooting/resetting
I switched to the 873.
KevinLiT
Aug 25, 2023NETGEAR Moderator
Hello Crasje ,
Welcome to the NETGEAR Community!
I understand that you are not able to see the satellites using your Orbi app. This behavior usually occurs when the Orbi app version is not current. Please visit the Google Play Store or the iOS app store to ensure your Orbi app version is up to date.
Best,
Kevin
community Team
