Crasje
Aug 24, 2023Tutor
RBR50 no longer detects satelites
hi, i noticed on the app that the satelittes were no longer connected. So I brought them closer to the Router and pressed connect on all 3. They all started blinking white for short period, one o...
- Mar 21, 2025
conclusion was that the satellite is broken beyond fixing/rebooting/resetting
I switched to the 873.
Crasje
Mar 10, 2025Tutor
Hello,
my satelitte is suddenly disconnected, i tried to pair or reset but no succes.
now i noticed in the orbi app that i see older firmware for that satelitte, so my plan would be to update it to 2.7.5.6 (from 2.7.4.24).
doing it via orbilogin is not going to work since it is not connected, so how do i proceed?
thanks!!
Mar 11, 2025Guru - Experienced User
Does pressing the reset button for 15 seconds then release on the back of the RBS change anything?
Try a 30-30-30 reset as well. If this fails, possible RBS has gone bad.
Try this as well and see if the self service web page works:
- CrasjeMar 11, 2025Tutor
Hi,
pressing reset does not work so far I tried it 3-4 times. Also turing it off for 5+min doesn't work.
Today I hardwired (ethernet) the RBS50 to the RBR50 hoping it would make it visible for the ORBI management software so it could be updated via http://orbilogin.com (assuming only pairing etc was broken) but that did not work either.
I have read somwhere that perhas connecting the SBS50 directly to a laptop was an option? But I can't find it anymore or how to flash it from a Macbook.
