Crasje
Aug 24, 2023Tutor
RBR50 no longer detects satelites
hi, i noticed on the app that the satelittes were no longer connected. So I brought them closer to the Router and pressed connect on all 3. They all started blinking white for short period, one o...
- Mar 21, 2025
conclusion was that the satellite is broken beyond fixing/rebooting/resetting
I switched to the 873.
Crasje
Mar 10, 2025Tutor
Hello,
my satelitte is suddenly disconnected, i tried to pair or reset but no succes.
now i noticed in the orbi app that i see older firmware for that satelitte, so my plan would be to update it to 2.7.5.6 (from 2.7.4.24).
doing it via orbilogin is not going to work since it is not connected, so how do i proceed?
thanks!!
Crasje
Mar 21, 2025Tutor
Conclusion was that the Orbi RBS50 was beyond fixing, reseting to factory, rebooting, whatever... had no effect.
So I spend a bucketload on the Orbi 873, very quick internet now đ
