MCO79
Mar 03, 2020Tutor
RBR50 no longer showing Detected Devices
As the subject says I can no longer see any connected devices in the iOS app or a web browser. This all started when the Armour Subscription expired. I have a ticket with tech support but Im getting ...
- Mar 14, 2020FWIW the latest firmware 2.5.1.8 solved this issue. the devices are now showing under the app and the web interface. thanks
MarcoBru
Mar 14, 2020Tutor
same issue here.
exactly same.
Thats probably the minor of the issues I 've with orbi, and I'm a new customer.
In any case, the app 2.4.21.5 is one week old. I'm totally sure that THIS issue arises from this app that is bugged
- FURRYe38Mar 14, 2020Guru - Experienced User
What Firmware is currently loaded on the Orbi system?
Try to remove and reinstall the app. Try other mobile devices to compare
For any Orbi app problems or information,
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-appAs notited, the OP for this thread has his working on FW v2.5.1.8
MarcoBru wrote:same issue here.
exactly same.
