jchomsky
Oct 01, 2021Aspirant
RBR50 no longer works - factory reset does not work
Hello all Was hoping for some help - my RBR50 stopped working - now the lihght in the back is green, but when i try to do things like reset, 15 secs, then reset while power cycle etc...nothing happe...
Oct 01, 2021Guru - Experienced User
what happens when you push and hold reset for up to 30 seconds?
are you able to hardwire a pc/laptop into the router and connect to it?
what modem/gateway is it connected to?
jchomsky
Nothing - light stays green
Tried, unable to
Had it on Virgin Superhub - disconnected and simply use the Virgin modem now.
- plemansOct 01, 2021Guru - Experienced User
If you disconnect the router from the hub/modem entirely, then reboot the router, will a pc/laptop be able to connect/log into it?
- jchomskyOct 01, 2021Aspirant
thank you for your response! Unfortunately nothing happens.
It does not feel like it is rebooting either...(top lights are not coming on on the router)
Wondering if the reset button isn't broken as you should get a change by pushing/holding reset for 7-15 seconds. The power light should change/blink
