jchomsky
Oct 01, 2021Aspirant
RBR50 no longer works - factory reset does not work
Hello all Was hoping for some help - my RBR50 stopped working - now the lihght in the back is green, but when i try to do things like reset, 15 secs, then reset while power cycle etc...nothing happe...
CrimpOn
Oct 01, 2021Guru - Experienced User
jchomsky wrote:
What router can i buy that supports my RBS50s?
Any of the original Orbi routers will support the RBS50 satellites, although only an RBR50 will have the same performance. (Depending on your internet connection, "top speed" may not be a concern. Many customers seem happy with their RBR40 or RBR20 routers.)
There are often many RBR50, RBR40, and RBR20 routers on eBay because people wanted more satellites, purchased a "kit", and then decided to sell the surplus router.
The "Pro" and "AX" routers will not sync with the RBS50 satellites.
