davidphil01
May 13, 2021Aspirant
RBR50 No reset, no wifi, flashing white, tftp no help... cost to repair?
RBR50 was working fine in the AM, came back after 2 hours and it was blinking white... and no longer broadcasting the network to connect to. I tried resetting.. no luck, successful updated via tftp,...
microchip8
May 13, 2021Master
If you're within the warrenty period, NETGEAR should have not problem replacing it. Otherwise "it's dead, Jim" and you should look at something else
