imrazzed's avatar
imrazzed
RBR50 not downgrading firmware
In the past I had some large issues with awful connection and I jumped through hoops for weeks trying to fix it, I finally fixed it by downgrading the firmware to an older version. This issue has come up again so I went back to downgrade the firmware as NetGear for some reason forces updates on their users. I've tried downgrading the firmware of my Sattelite to version 3.5.30 multiple times, each time it starts loading and before it gets to 100% the system restarts and comes back online with the current version. I've tried doing this wirelessly and while connected to the Sattelite, I even tried doing it while connected to the main Home Orbi. I've tried resetting the whole system multiple times and no matter what I do it's not downgrading the firmware.
    • imrazzed's avatar
      imrazzed
      I tried that firmware but I had the same issue, I factory reset my Orbii and finally got it to downgrade to 2.3.5.30 but still having the same issues. Awful connectivity where games have insanely high ping spikes leaving everything unplayable.
      • CrimpOn's avatar
        CrimpOn
        There have been many posts on the forum complaining that the Orbi auto-updates to V2.7.3.22 by itself, so even though the downgrade was successful, it may not have stayed on that version.  There are two methods to prevent the router from auto-updating, but each has "pros and cons".
        Would it be convenient to connect the gaming computer directly to the ISP device for a test?  If the ping spikes exist when the Orbi is not part of the network, then the issue is probably the ISP network.  If the ping spikes disappear, then the focus remains on the Orbi.
  • FURRYe38's avatar
    If thats the case then problems maybe coming from ISP modem or ISP services.
    Are you wired or wireless when gaming?
