tallg
Dec 09, 2021Follower
RBR50 not listing all connected devices
In both the app and the web interface only a three devices out of the many connected to the wifi are listed as Attached Devices. Latest firmware version loaded (V2.7.3.22).
1 Reply
- Streak2Master
I have had this happen on and off with my RBK50 as well.
Sometimes its due to firmware versions that are not in sync across the router/satellites.
As mentioned in a previous post.
Connect to the router using web brower using the IP Address of the unit, then go to Advanced->Administration->Firmware Update
It will then scan your system and provide all the Firmware revision on each individual unit. If any are mismatched, it will allow you to click "Update All"
Then you should be good to go, you may need to do a complete power cycle of the router, and a refresh of the modem.
