Maboza
Sep 11, 2022Initiate
RBR50 not responding
Hi, I have an RBR50 that is not responding to any packets that are addressed to it, so I cannot reach the local GUI or via the app. Initially I thought that the RBR50 was not forwarding any packets, h...
CrimpOn
Sep 11, 2022Guru - Experienced User
Maboza wrote:
I also see that it broadcasts the SSID I configured as well as the factory defined SSID which seems to be strange after a factory reset. I have also factory reset the satellite Orbi and now I cannot get it resynced as I cannot reach the RBR50.
I have done Factory Resets numerous times, and every time the router broadcasts only the SSID defined on the product label.
Did you physically observe the power LED turn amber and begin to flash?
ekhalil
Sep 11, 2022Master
What is the make and model of ISP modem/router to which RBR50 is connected please?
