SdeGat
Jan 06, 2022Apprentice
RBR50 on Xfinity: Avoiding two separate networks?
I recently got the Xfinity internet/TV service (called Hélix over here) and just plugged in my RBR50 into one the Xfinity box ports and that was it. Everything has access to the internet including th...
- Jan 06, 2022
This is an awkward question. There are two WiFi networks because the Xfinity and the Orbi are both creating WiFi networks. Putting the Orbi into Access Point (AP) mode will not change that.
If all of the devices that are currently connected to the Xfinity WiFi are connected instead to the Orbi WiFi, then everything will be on one network and everything will be 'visible' to everything else.
Most customers would go into the Xfinity management system and disable WiFi because it is no longer needed.
It is an awkward question because there is an additional complication. The Xfiniity router and the Orbi router are both 'routers'. This creates what is called a "Double NAT". (do an internet search) Thousands of customers are blissfully unaware that having "two routers" can be a problem because none of their activities are affected. For those few who ARE affected by a Double NAT, there are a number of solutions.
Bottom Line: Only have one WiFi network. Turn off the Xfinity WiFi and connect all devices to the Orbi WiFi.
CrimpOn
Jan 06, 2022Guru - Experienced User
SdeGat
Jan 07, 2022Apprentice
Thanks for detailed info CrimpOn. Turning off the Xfinity wifi is not an option as it provides the better performance of the two routers. 💁♂️
I guess I'll have to get rid of my Orbi (😞) and get some Xfinity pods to keep everything on a single wifi network.
- CrimpOnJan 07, 2022Guru - Experienced User
Oh, my. Better speed? More stable? Ability to split 2.4G from 5G? Surely not wider coverage?
- SdeGatJan 07, 2022Apprentice
That's what I was led to believe with its wifi6 and the rest.
Is it not better than my "old" RBR50?- CrimpOnJan 07, 2022Guru - Experienced User
"Better" is such an awkward term.
It is true that the RBR50 is only an "ac" product. It supports 802.11b/g/n for 2.4G WiFi and 802.11ac for 5G WiFi. It does not support WiFi6 (802.11ax) Alas, I have zero devices in my home that include 802.11ax capability. Since the capability is part of the actual WiFi hardware, nothing that I own will ever have WiFi6. Not my laptops. Not my phones. Not my tablets. Not my TV. Certainly not my growing array of Internet of Things (IoT) gizmos (smart plugs, thermostat, smart bulbs, speakers, etc. etc.). Buying a WiFi6 router gets me exactly zero. Suppose I get a new phone that includes WiFi6. Then, I will have one device that in theory could benefit from having a new WiFi router. Alas, I have only a 200mb/s internet connection. Will having WiFi6 make that faster? No.
If I were buying a new WiFi system today, it would seem prudent to "future proof" it by getting WiFi6. But wait, what about WiFi6E???? Products are coming on the market every day that can use the 6G WiFi band. Maybe I should spend even more.
It boils down to performance and coverage. How much will it cost to install (monthly rent?) additional Xfinity units to match the existing Orbi WiFi coverage area?
Sorry to ramble on. I get carried away.
