freesole
May 04, 2020Aspirant
RBR50 once set to AP mode cannot detect satellites
So I set my RBR50 router to AP Mode (back story is that I am doing this so Xbox Live can work) and now my two satellites (RBS50) cannot be detected on my network map (on the network map, the color is...
CrimpOn
May 04, 2020Guru - Experienced User
Perhaps a few more details will help.
- The Orbi is now in AP mode, which means that the ISP device it is connected to is a "router", correct?
Can you provide the brand and model number of the ISP device? - Apart from the satellite showing magenta dots, is it correct that there are WiFi devices connected to the satellites which are actually working?
- Have you opened a web browser and connected to the Orbi web management interface and opened the "Attached Devices" page?
When in AP mode, I am not confident that the Orbi will resolve "orbilogin.net" to the Orbi IP address (maybe it does, but I can't use AP mode so I can't verify that.) I would browse to http://<ip of orbi router> where the IP address should be found on the App under the router description.
freesole
[Response] Correct - The house is wired for fibre optic and through a Worldwide Packets 38SF switch. - Apart from the satellite showing magenta dots, is it correct that there are WiFi devices connected to the satellites which are actually working?
[Response] Well that's the thing, my wireless devices are working but when I log in to Routerlougin, there are no devices attached showing. - Have you opened a web browser and connected to the Orbi web management interface and opened the "Attached Devices" page?
[Response] How do I find the IP of my router?
