jhg777
Oct 30, 2023Aspirant
RBR50 OpenVPN on iOS
Hi. I can successfully connect to the OpenVPN server on my Orbi RBR50 router from my iPhone (13 mini running iOS v16.7.2) ONE TIME. After that, it fails to connect unless/until I reboot the router. ...
Oct 30, 2023Guru - Experienced User
jhg777
Router firmware: V2.7.4.24
Modem is Cisco DPC3216 / 271875498
- FURRYe38Oct 31, 2023Guru - Experienced User
Might review FW updates:
- jhg777Nov 07, 2023Aspirant
I did apply the new firmware. This seemed to have helped...for a while. The error messaging seems different. See logs attached. It seems to connect (even consistently over a couple of days), then suddenly no go. I can't seem to figure out why "can't assign requested address". Note: I have no "other VPNs" running; I am disconnected from WIFI, and I can access internet using cellular network. See logs below showing a successful connect followed by a failure. I appreciate the assistance!
- CrimpOnNov 07, 2023Guru - Experienced User
not confident that this discussion is helpful (or not):
https://www.reddit.com/r/OpenVPN/comments/13xiim5/openvpn_ios_client_always_fails_first_time_to/
