GTSMike
Jul 22, 2018Aspirant
RBR50 or RBR40, what is best for modern 2 story condo
I just bought a RBR50 for a 2000 foot 1 floor condo. since the router has to plug in to the WEBpass connection at the one end of the condo i got tired of having the signal drop when at the other end ...
GTSMike
understand about material. that is why i mentioned modern condo and concrete floor between the two levels. Before i had a 1930's house with latch and plaster walls. the plaster is on chicken wire. it was like being in a Faraday cage. i am sure the concrete floors are filled with rebar
Jul 22, 2018Guru - Experienced User
Ya, if you have some concreate, you may need to move the satellite a bit closer if your going to use wireless back haul between them....
