Chitat
Jul 24, 2019Aspirant
RBR50 Orbi DHCP assigned some IPs that cannot access to internet
My Config RBR50 restricted DHCP IP range from 21 to 99, but some of the devices auto assigned .1XX and cannot access to internet. This situation appear not only in wifi but also in LAN environment, I...
- Aug 14, 2019
Your ISP modem/ONT has a built in router already. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option #2 first, then try #3 if this doesn't change anything.
I would also change the IP address pool size on the RBR to 192.168.1.100 to .200 while the RBR is in router mode.
Jul 24, 2019Guru - Experienced User
Factory reset the RBR and this time, set the DHCP IP address pool size for 192.168.1.100 to .200. Anything inside this pool will get auto IP addresses that can be reserved ON the router. Anything on either side of this pool can be static IP addressed ON devices.
What devices do you have all connected to the system?
