Chitat
Jul 24, 2019Aspirant
RBR50 Orbi DHCP assigned some IPs that cannot access to internet
My Config RBR50 restricted DHCP IP range from 21 to 99, but some of the devices auto assigned .1XX and cannot access to internet. This situation appear not only in wifi but also in LAN environment, I...
- Aug 14, 2019
Your ISP modem/ONT has a built in router already. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option #2 first, then try #3 if this doesn't change anything.
I would also change the IP address pool size on the RBR to 192.168.1.100 to .200 while the RBR is in router mode.
Chitat
Aug 13, 2019Aspirant
i reset to default setting and setup a ethernet backhaul with 1 satelite. fixed a device IP in LAN configuration, but still can't fix the problem
for example, my iphone reserverd a IP 192.168.1.7 in orbi configuration,
i still get a strange ip in my iphone 192.168.1.100 without internet access
and after i forget and rejoing the wifi network, it may sometime get a ip that can connect to internet,
let say 192.168.1.22 but i can't get my reserved ip 192.168.1.7
In order to make the device work with my reserved IP, i have to set both orbi donfig page and device configuration, however, some of my device have no static ip configuration.
Another strange situation, i have a set top box with an DHCP IP 192.168.1.23, everything work find, and sometime it will auto switch to another ip without internet access, let say 192.168.1.155
After my investiguration all IP that larger than .100 will not have internet access
My configutation is fibre -> HUAWei HP8045 -> WAN -> Orbi RBK50 + satlite
Aug 14, 2019Guru - Experienced User
Couple of options,
