wagnermba's avatar
Jun 26, 2022
RBR50 Orbi Guest Password Doesn't Work
Hi: I set a guest password for my RBR50 Orbi Router -- using Orbi app on iPhone and also from the web admin page.  But, whenever I try to login to it via phone or computer, it says "incorrect passwor...
  • plemans's avatar
    Jun 26, 2022
    Try removing the special characters from the ssid/password?
