mediabiz
Dec 21, 2020Aspirant
RBR50 Orbi Router Cant connect to NBN
Hi, I bought a ORBI RBR50 system a couple of years ago to act as an access point as the WiFi from the iPrimus supplied NBN router was crap. At the time, I needed my VOIP landline, so I had to keep t...
mediabiz
Dec 22, 2020Aspirant
Yes, that's correct, it's connected to iPrimus.
The router they supply is the Audiocodes MP264 - a widely used by several ISP's that is very cheap and has popped up as the culprit of many issues in various forums.
I have the NBN Co supplied fibre modem (the standard modem installed) plus the iPrimus Audiocodes router.
CrimpOn
Dec 22, 2020Guru - Experienced User
mediabiz wrote:I have the NBN Co supplied fibre modem (the standard modem installed) plus the iPrimus Audiocodes router.
If the fiber modem has no product label, could you post a picture of it?
(use the Browse..." button in the lower left. Pictures posted "in-line" have to be approved by a forum moderator, which can take days.)
My son in North Carolina had fiber put in and the installer ran it inside the house all the way to their fiber box, which has an optical connector on it and an ethernet jack for his router. Not being familiar with iPrimus, I don't even know if the optical fiber plugs into this "Modem"... or what.
