Stallion69
May 12, 2021Tutor
RBR50 (Orbi Router) Firmware Version 2.7. 2.104.
Is it safe to download the latest firmware version (2.7.2.104). Reading on comments in the community and online, there are some bugs in it. Please help....
May 13, 2021Guru - Experienced User
IF yoru system is working. Keep what you have. If you do decide to update. Manually download and manually install the FW. Power OFF the system for 30 seconds then back ON. Don't update using Orbi app.
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/RBR50-Have-You-Installed-V2-7-2-104/m-p/2055212
https://community.netgear.com/t5/Orbi/Orbi-RBR50-Router-Firmware-Version-V2-7-2-102/m-p/2028357/highlight/true#M109645
https://community.netgear.com/t5/Orbi/New-Orbi-RBR50-Router-Firmware-Version-V2-7-2-104-Released/m-p/2050687/highlight/true#M113392
Good Luck
