Stallion69
May 12, 2021Tutor
RBR50 (Orbi Router) Firmware Version 2.7. 2.104.
Is it safe to download the latest firmware version (2.7.2.104). Reading on comments in the community and online, there are some bugs in it. Please help....
Stallion69
May 21, 2021Tutor
I haven’t upgraded yet. I’m a little hesitant.
My ORBI is working fine right now. But I think I will upgrade it the way u mentioned instead of the APP.
My neighbor has the same ORBI and she has it somehow set up where it upgrades automatically through the ORBI App. It’s been running fine so far for her.
May 21, 2021Guru - Experienced User
Ok, you can keep whats loaded for now as well if it's working. :smileywink:
- Stallion69May 27, 2021Tutor
Yes I will for now. Thank you very much....
- FURRYe38May 27, 2021Guru - Experienced User
Enjoy.
