anomura1
Sep 05, 2020Follower
RBR50 ORBI router ring light blinking white light
My ORBI router stopped working and is now blinking a white light. I’ve disconnected it and tried plugging it back in and setting it up through the ORBI app but it’s still blinking white and can’t conn...
Sep 05, 2020Guru - Experienced User
Pulsing white usually indicates the orbi router/satellite are applying a configuration change/updating firmware.
If its stuck blinking white, try factory resetting it.
Push and hold reset for 7-15 seconds while its powered on.
