ksaheta
Oct 04, 2020Aspirant
RBR50 Orbi Wifi Wifi Channel selection dropping upload
We installed Netgear ORBI RBR50 Wifi Mesh system (1 base, 1 satellite) in our home a few months ago. We have a 1Gigabit/second Google Fiber Internet connection. Most apps (movies, streaming, ...
Mstrbig
Oct 05, 2020Master
You could be experiencing channel interference or possibly you need to open some ports through port forwarding, that support VOIP, WIFI calling, video, etc. You can search for port suggestions on the NET for your specific needs.
- ksahetaOct 06, 2020Aspirant
Thanks!
I have confimed no ports are blocked.
How do I minimize or avoid channel interference ?
Thanks
- FURRYe38Oct 06, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849 - MstrbigOct 06, 2020Master
ksaheta wrote:
Thanks!
Thanks
You can run a program like NetSpot to check what channels neighbors are on and choose a different channel. 2.4Ghz is important as it will get the most interference. I found my channel 1 was less used, so I switched to it. 5Ghz has less coverage area, so you can choose pretty much any channel. I chose 48.
Also check these settings for optimum performance:
Disable Circle, Armor, Daisy Chaining, Fast Roaming, IPv6 and uncheck 20/40Mhz Coexistence.
Enable WMM, Implicit BeamForming, Mu-MIMO
Set Short preamble mode. Save settings, reboot Orbi.
